Ga door naar hoofdinhoud
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Vragen Bekijk alle
My phone keeps overheating and shutting off
So my galaxy s8 has started having this problem for a while maybe started 8 months ago. But if I have my brightness up too high and use it too long or play a graphically intensive game. The side with the power button will get extremely hot. This also happens if i’m in a hot environment or humid one and I even use the phone for too long. Then eventually it will shut off and if I turn it back on it will just shut back off so I have to wait maybe 15 minutes to turn it back on in order to use it. Other problems is it says its fast charging then switch to cable charging but charge at the same speed. Ive had the phone for two years now but I really don’t want to get a new one, so what should I do?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
May be u can factory reset and see if it helps.
A old used battery also is reason for heating. Just
Samsung Galaxy S8 Vervanging van de batterij
Was dit antwoord nuttig?
When I used phone s8 plus after over heat phone was atomuticly switch off and coming some different sound how canning fix it
Voeg je antwoord toe
Alex Salazar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 2,208
