Ga door naar hoofdinhoud
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Not recognizing new hard drive
When I tried to installed MAC OS 10.5. the system does not seeing the new drive and when I goes to utilities, still not seeing the new drive. ALl it see is just the DVD and nothing else. What I do I need to do...HElp
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Use Disk Utilities on your system installation disk and format the drive before trying to install a system.
UPDATE - Problem Solved
The new SATA drives need to be jumpered. I placed a jumper on pins 5 - 6, setting it to 1.5 GB. The drive came right up
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Actually I'm having the same problem right now. I'm trying to format a 1 TB Western Digital Caviar Black. I've tried it in a 20" 2.0 G5 iMac and a PowerMac dual 2.0 and the 10.4 system disk is not seeing it in Disk Utilities, this is the second HD in two days, I returned the first as DOA. Will try 10.5 next. Any ideas?
door
+ Apple EFI doesn't like SATA 3GBs drives. I am perplexed by this. More so, after I learned it is due to driver extensions.
door
If Disk Utilities doesn't see your new HDD check the wiring. If still out of luck try the disk externally or in a different Mac and try to format it there. Remember, on a PowerPC based machine you'll need to format it with the Apple Partition Table as opposite to the GUID table on Intel based machines.
Score 2
1 Opmerking:
Wiring look ok. Tried external and able to partion it to apple partition but when I tried to installed the 10.5 MAC OS to the external HDD I m still unable to complete the installation.
door
Voeg je antwoord toe
traudien zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 5,665
