Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
My battery had swelled
The battery swelled and caused the screen to crack when i contact Apple they can fix the battery but will they also fix the screen too since it wasn’t damage till the battery started getting bigger?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I don’t see why they wouldn’t fix it…but they will charge you for 2 repairs, the battery and the screen. You are responsible for having the battery replaced before it causes damage to the screen.
Was dit antwoord nuttig?
Score 2
They should. Swelling batteries are usually replaced no questions asked, and they may give you a slightly newer phone. It’s also possible that they’ll refuse you since it’s out of warranty, but if the swelling is significant, I doubt it.
Score 1
Voeg je antwoord toe
DeiShawna Foust zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 44
