Recently replaced battery and now the MacBook is overheating
I recently replaced the battery in my early 2013 15” Macbook Pro Retina Display with a battery from iFixIt, following their instruction manual. Now my Macbook is getting much warmer than it ever did prior to the battery replacement. The fans seem to be running at proper speeds. What could be causing my macbook to heat up?
Is dit een goede vraag?
3 opmerkingen
Let's see if we can get a better look at what's happening. Install this gem of an app CoconutBattery this will allow you to get a better view of the battery. In addition lets look at the thermal sensors and fans, install this great app TP Pro
Take snapshots of both apps main windows (you'll first need to adjust the TG Pro window so all of the sensors are visible with the fans). Post them here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
My replacement is hotter than normal as well.
door Robert Bacarella
@robaca - Can you give us what I had asked, so we can figure out whats happening.
door Dan
