Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Can the HDD be replaced with a SSD
Is there a SSD compatible with the iPod Classic?
Is dit een goede vraag?
Score 17
Voeg een opmerking toe
11 Antwoorden
Gekozen oplossing
Yes, you can use a 1.8" "ZIF" SSD in your iPod, such as this one, however, since they are thinner than the "Fat" hard drive in your model of iPod, you may need to find a way to secure it inside the case to prevent rattling.
Was dit antwoord nuttig?
Score 11
8 opmerkingen:
Thanks Chris, that is a good starting point. Ideally, I don't want to lose that much of the capacity, anything > 100GB that you are aware of?
door
You can get a 128GB SSD and maybe a 256GB SSD, but they're not cheap.
door
Dominic, did you mean to accept the answer that helped you? Right now you accepted your comment as an answer.....;-)
door
Hey OldTurkey. I know, ridiculous isn't it, but I could not see how to accept the response from Chris Green. Perhaps, thinks I, the system will accept the most recent comment? Obviously not. Oddly enough, I returned to the site on receipt of the email from Chris and his response was not even there. After refreshing the page, clicking on his page, returning, switching between views etc it eventually appeared.
door
3 commentaren meer tonen
A couple of years later, a less expensive solution is to get the Sintech PA6007 1.8" ZIF/IDE to mSATA adapter and mount a standard mSATA SSD on it.
The Sintech adapter is about $15 on Ebay, $20 on Amazon, and I've seen it as low as $10 around the web. The interfaces are all proper, but I'm not sure if there are power demand issues.
240GB mSATA SSDs have been turning up at Holiday sales this year (2013) as low as $130 -- mainly at Amazon and Newegg.
So for under $150 one can get 240 GB of storage.
Of course, just before the Toshiba MK2431 was discontinued, one could get 240 GB of much slower storage for ~ $75.
Score 6
5 opmerkingen:
Thanks, Jeff! I was looking for a solution like that. I just ordered the mSATA and adapter.
I work in an area where they do allow iPods, but do NOT allow anything with a radio (bluetooth, WiFi). Sadly, I have no hope that Apple will remake the Classic with an SSD. The 6th Gen Nano works, but it's only 16GB. If this mSATA solution works, I will probably end up getting a few Classics and 'upgrading' them.
door
I'm glad I was able to help. Watch the cable orientation. I had the cable upside down at first, and, of course, that doesn't work. The tricky bit is that I carefully compared the cable orientation on the original hard drive to the cable orientation I used on the adapter and was sure I had it correct. It turns out, on more careful examination, the cable connector on hard drives is actually mounted on the back-side (from you) of the board and protrudes through a cut-out in the end of the board. So the cable connector on the hard drive is actually upside down to how it looks on first examination.
door
Hi, Jeff. I stumbled across your replies while trying to figure out the best way to upgrade my hard drive after my Ipod screen started displaying the red x. I have replaced my battery and upgraded the hard drive using the adapter you suggested with Crucial 120gb mSATA SSD. The Ipod screen is still displaying the red x. I've checked cable connections and reversed them to verify, but nothing seems to help.
Do you have any other reccommendations? Thanks so much!
door
The only problem is that mSATA uses almost as much power as a hard drive. The better option is to use an iFlash Quad from iFlash.xyz .... uses far less power. If you combine that with a 3000mAh battery and larger backing, your iPod will literally play for 14 days if left playing 24 hrs. a day. So for casual listens at work for 8 hours a day, that means you'd only have to charge the player once per month.
door
To amend my comment here.... you can fit the iFlash board with a thin backing and the 3000mAh battery. People told me I needed the larger back, but you actually don't.
door
Best solution, IMO, is the iFlash Quad at iflash.xyz
I don’t know if this unit can take 512GB micro SD cards yet since they’re a bit expensive at the moment, but 400GB micro SD cards work just fine in it and use very little power. My unit with 3000mAh battery gets charged only once per month and is never low on power when I charge it. Performance is excellent on it too. To fill up my 1.6TB iPod, it does take about 16 hours, but subsequent syncs take maybe 2 minutes to download the database file from the iPod (which is in itself 1.5GB in size). After that, it goes fast.
Score 3
8 opmerkingen:
iflash.xyz was my solution too. Worked without any problem.
I doubt that you can load an iPod (thick, 2007) with more than 120 GB (SSD) though. Just the youngest iPod generation can be equipped with such large SSD drives when using iTunes as player.
door
No, that's partially right. The 1.x models of the iPod Classic have an LBA28 limit of 128GB which you can't really get around (except with the thick 160GB drives from that era). Get a mainboard of 2.0.4 or 2.0.5 and you definitely can go beyond 128GB. For Windows, the limit would then be 2TB. Not sure if the HFS format of Apple lets you go higher but since we're limited to 512GB cards at the moment (in terms of feasibility and price), you can't really break 2TB just yet. And I have 1.7TB on my 2.0.4 model with a 512GB and 3 400GB cards. You can fill it up.... it took me just about 2 days to do it, but you can do it. :) I highly recommend stopping sync every 6 hours or so to give you a good checkpoint because one hiccup and it won't commit the sync for what you just put on it. :)
EDIT: But people have said the 5th generation Video iPod also does not have an LBA28 limitation and can go up to 2TB. The issue is that there's less RAM in it so the more you add, the more problems you have. I think if you have about 10000 songs, you're probably OK. Go to maybe 30k songs and you might start having problems.
door
But if you have a 1.x Classic, you can just swap out the mainboard for a 2.0.4 or 2.0.5 model. The issue comes where you have to clean the partition table of the cards or else you'll have issues in iTunes and such. Just take out each one, open DiskPart in PC, select disk (very important here... also use LIST DISK to make sure you selected the micro SD card drive), then type CLEAN. No confirmation comes up, nothing.... except a confirmation it was successful... Then plug it back in and restore with iTunes.
The CLEAN aspect is key if going from one firmware to another. I went from a 2.0.5 to a 2.0.4 when the 2.0.5 dock connector broke and this was required for it to work right. But after that, it has been fine since.
door
I'm with you @alissa914 - The iFlash-dual is what I have in mine I just love it!
door
hey there @alissa914 ,
do you have any specific ebay sellers you'd recommend for both the 3000mAh battery as well as the 400GB cards? hope you don't mind me asking, but i just had my ipod's HDD die on me the other day and while searching for different replacement/upgrade options i came across this comment which sounds exactly like what i'm hoping for.
door
The 1Tb option has been tested here http://www.tarkan.info/20141029/tutorial...
Score 1
1 Opmerking:
Before people start buying 1TB micro SD cards (yes, I know this is an old post), keep in mind that even that Dank Pods guy tried four 1TB cards and had sporadic success with such cards. One that I bought for $250 a few years ago will not work. It does read but once you add other cards, the board can't handle the space and returns odd results. It may be iFlash's issue but regardless, Windows has a problem with > 2TB due to signed 32-bit integers representing space. iPod has 4k sectors so theoretical limit with MBR is 8TB (as MBR is limited by # of sectors)... but Windows and Mac have issues with it having more than 2TB. I've tried both.
door
I had the same issue. The second time I took it apart, I ripped one of the ribbon cable connections from the motherboard and ended up scrapping the entire iPod. I have a ZIF converter and a 128GB mSSD if somebody wants it!
7 opmerkingen:
Can i have the ssd and the conventer pleasejohn please i need it so bad!!
door
If you still have those, would you mind giving them to me? Thanks so much!
door
can i have the ssd converter or tell me the converter that i need for the 5th ten 30gb ipod classic
door
still have those parts?
door
Crap sorry. They got trashed by accident soon after I messed up the install.
door
2 commentaren meer tonen
sooooooooo would this work? for the 'thick' version ipod classic 6th gen 160GB? or naw?
1 Opmerking:
Yes but remember that 1.x iPod Classics are limited to 128GB using the stock firmware. The 160GB model can break that for the hard drive only but for an SSD, it's 128GB.
If you want more than that, you have to swap the mainboard with a 2.0.4 or 2.0.5 version. But if you're in the market for it, go iFlash Quad.... better than the SSD (more power efficient) but more importantly... expandable.
door
Now this would be a good one, a bit expensive though, but totally worth it.
A 1TB iPod Classic!
SAMSUNG 840 EVO mSATA
9 opmerkingen:
I'm not sure how much storage the Classic models can address. For example, according to a forum post I saw elsewhere (ipodwizard.net), the 5.5 Gen iPods can only address to 240 GB, so I'd be hesitant about buying an expensive SSD for this kind of brain surgery without being sure that it will work in a particular model.
door
i can only find laptop harddrive,can you give me a link to a ipod classic 7 gen 1 tb drive,please
door
ebay would be your best bet. Just look up "1TB mSATA"
door
i did see the ssd but i would like to know which ipod generation will it work
by the way : will this work?
http://www.amazon.com/Samsung-850-mSATA-...
door
From what the website said, msata would work best with the 7.5 gen ipod classic. Aka the very last of them before they were pulled from market. As for the evo, that should work. You still need the zif adapter
door
4 commentaren meer tonen
So what happens after you do a successful drive swap to an SSD? Does the iPOD OS have to be loaded somehow?
3 opmerkingen:
You load the software just like u do with the regular hard drive.
door
I guess I'll YouTube that because I've never done that before... Thanks.
door
Basically, you put it in and then you get the popup that says "Connect to iTunes to restore." Then you hit Restore, it formats and installs it, then reboots. Very painless nowadays. The firmware is about 35MB or so and that usually downloads in a minute on modern internet connections.
door
My iPod is only recognizing 57gb of the 256gb installed. Do any of you have a solution for this?
2 opmerkingen:
what gen is your ipod?
door
This could be a partitioning issue. If you have a 5th gen or later, try getting a 1.8" ZIF to USB adapter from Amazon (or eBay too, I guess). Go into DISKPART, select DISK (*absolutely* make sure you select your 1.8" ZIF drive for your iPod and not your boot disk... double check with LIST DISK to be safe).... after you confirm that, type CLEAN. That removes the partition table. Don't initalize it in Windows again... just put it directly into the iPod. Boot the iPod back up and it should tell you to connect to your PC/Mac and use iTunes to restore. Then Restore in iTunes.
If you have a 1.x iPod Classic, you'll only see 128GB. 5th gen and 7th gen? You should see the whole thing.
door
As an FYI… one guy on a message board got four 1TB micro SD cards and put it in an iPod Classic…. the unit could only read 2TB in Windows.. the cluster size of the iPod disk is apparently 4kB so the limit should be 16TB…. anyone with a Mac want to try to go over 2TB with HFS+ formatted iPod? If you have, please post here… a lot of us are wondering. If I had a Mac Mini, I’d try it myself.
Apple got rid of the firmware download so how does this even work anymore? More specifically x12230000_Recovery.ipsw
1 Opmerking:
Not sure about over 2TB.. but just wondering, who’s out there running 2TB (x4 512gb mini SD) and 3000 mah? This combo seems like the holy grail, and I’m keen to go all in. Would love to hear.
door
Voeg je antwoord toe
Dominic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 170
Altijd: 95,992
