Ga door naar hoofdinhoud
The Microsoft Lumia 540 is a low-cost smartphone identified by model number RM 1141.
5 Vragen Bekijk alle
How can I Recover data without PC?
Hello.
So I have a Microsoft phone (model: RM-1090)
And there is an issue. I need to recover files and images because they were deleted after a hard reset. Problem is, that I cannot charge this device with an ordinary charger because the usb (on the device) is not functioning. So everytime I want to charge the device I have to manually remove the battery and charge it, in an external charger.
The usb not functioning means that I cannot connect my phone to a pc so I can recover the data.
Is there any way, to do the recovery procedure inside the phone without using pc?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi ,
Since the phone is working have you thought about using Bluetooth to transfer content etc to a paired BT device?
Here's a link that may help.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
GO4GAME zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 124
