Ga door naar hoofdinhoud
HP’s 2-in-1 convertible laptop released in April 2015, identified by model number: 13-4003dx.
9 Vragen Bekijk alle
Screen replacement ribbon too long, how to fix?
I just replaced the screen (digitiser and LCD) of my laptop. The screen and touch is working perfectly, but I haven't been able to glue it back down with adhesive, as the ribbon sticking out the bottom, that I plug into the board that controls the touch, is a bit too long, so when I put the screen into the casing, the bottom part sticks up and won't sit flush. Can I bend this ribbon to give it a kink so the screen lies flat? Or do you have any other tips/tricks?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Look at the original screen and bend the cable in the exact same way. The original should have same sized cable but it’s usually bended in a way for it to fit in flush.
Was dit antwoord nuttig?
Voeg je antwoord toe
Calypso McDonnell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 69
