Ga door naar hoofdinhoud
Device and repair guides for the Huawei P30 smartphone. Flagship smartphone from Huawei released March 2019, featuring a 6.1" OLED screen and an in-display fingerprint sensor.
20 Vragen Bekijk alle
Can I change an imei number
Can anyone assist me with the below item.
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->  <configuration>     <system.web>         <customErrors mode="Off"/>     </system.web> </configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<!-- Web.Config Configuration File -->  <configuration>     <system.web>         <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>     </system.web> </configuration>
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@phemelo there must be a reason why you would want to change the IMEI number (yes it can be done on some of the Android phones) Where the IMEI is used to trace the location of a device or find the stolen device, on the other hand its used to make a device untraceable by changing its IMEI number, serial number…etc. so you see why this is not going to be an easy answer.
Was dit antwoord nuttig?
Score 2
Yes, it’s possible to change the IMEI number on any cell phone models. To do this it’s possible only using Box Tool. This tool depends on the device phone model. For LG is Octoplus. For Samsung, you have Z3X Box Tool. You have here full guide and tutorial how to download this software for free and full instructions on how to use https://www.unlockbasecodes.com/how-to-c... very easy.
Score 1
Voeg je antwoord toe
Phemelo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 4,901
