Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De OnePlus 6T is een Android-smartphone van OnePlus. Het toestel werd aangekondigd op 29 oktober 2018 en uitgebracht op 6 november 2018.
Volume button got dented in
I sent my phone out for repair but they are saying the LCD assembly got damaged as well, is that possible for a small dent on the volume button to cause that damage?
Is dit een goede vraag?
Voeg een opmerking toe
5 Antwoorden
Filteren op:
is the volume button near any support or construction of the phone? Maybe they meant that the button cannot seat properly but I am not too sure.
Sorry I do not understand what you are asking
Could you expand please
Was dit antwoord nuttig?
Volume been dented in may be beacause the push connector on the inside which is on a cable maybe damaged
Is there damage to the frame of the phone by the Volume button
1 Opmerking:
Hi Jerry! Okay, the volume button was dented in with the frame of the phone rendering the button unpressable. I am not sure about the construction of the phone or anything that has to do with the internals of the phone but all I know is that the frame and the volume button are fused together.
door Deel
The volume button and the frame are not fused together
1 Opmerking:
Yes, I understand that but do you think I can remove the volume button from the phone and bend it back into place. Then after I do that, I can sand the frame of the phone just a bit so that the volume button can move back and forth.
door Deel
If the main frame is bent . The best think to do is to get a new casing and transfter everythink over to it
If it working fine why not leave thinks has they are
1 Opmerking:
Yeah I might do that but the whole frame costs 140 dollars and this is just to repair the volume button. Is there any way I can just repair the volume button itself?
door Deel
Full frame with all buttons
https://www.ebay.ie/itm/173463031607
Voeg je antwoord toe
WARBUSCUS zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 15
Altijd: 658
