Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Can I put a Retina display on my older MacBook Pro?
Hi @nuka_kola and @danj thank you for letting us know it's possible! I also have a matt screen 2011 model 15" MBP that died due to gpu failure.
Do you think I could swap in a mid-2012 retina logic board? Or you'd rather go with a non-retina ones? It's the best deal I could find right now but I'm not sure if these two are different in terms of logic board. Will it cause problems when swapping? Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
A retina system uses a different video signaling method than the older non-retina systems
● Unibody 2012 and older - LVDS
● Newer Retina systems - iDP (also known as eDP)
You need to stick with the display the logic board supports.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Got it. Thank you for the details! I'll continue my logic board hunt.
door
Voeg je antwoord toe
Shuju zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 219
