Ga door naar hoofdinhoud
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer shuts off display CLL SVC
Have a kenmore elite dryer, front loading, steam not hooked up.
Dryer suddenly will trip a call service error, if I run an express dry (18 mins) it will heat up fine but shut off in the last 3 mins when it tries to switch to ‘cool down’
Clothes are warm, so the dryer appears to be getting heat.
Checked the vent at the back and there is no build up of lint or anything …
Update (07/26/2019)
here is a pic of the sticker inside the door
grrr i can only upload an image if its an answer?
Is dit een goede vraag?
2 opmerkingen
It cuts off on all cycles.
I’m going to run it now with the back vent off, the model number is 970L8110A0
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Does it cut off on all the cycles or just the express?
Try leaving the vent hose off the dryer and see if it still cuts off. If this is a gas dryer, you must open a window or door to operate it with the vent off.
If it runs fine without the vent, then you have a restriction somewhere in the vent hose or the vent in the wall going to the outside.
If this doesn’t help, we will need the model number off the dryer.
Was dit antwoord nuttig?
Score 2
13 opmerkingen:
So yes, unplugged the exhaust and ran a load.
Still shut off same place, switching from heat to cool.
door
any other ideas?
door
Mike, correct me if I’m wrong. Are you saying that it runs and heats fine on every cycle until it gets to the cool down? At the cool down on every cycle it stops running and gives you an error code to call service?
door
Mike Downs, I’m not finding anything for that model number. It’s located on a sticker around the opening of the door.
door
Oh I didn't see these responses, sorry ... I'll check the model number but that came off the sticker ...taking off a photo i took
sears canada inc
Model number 970L81100A0
Serial # 4D14803224
I've been using it by using express dry
i set a timer for 12 mins and go back before it gets to cool down
will take 3 or 4 12 min increments to complete a load .
is there a way to uplaod a pic i can give you the pic of the serial number
door
8 commentaren meer tonen
Voeg je antwoord toe
mike.downs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 4,675
