Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
How to fix the error 9?
the iTunes can not restore the ios because the error 9
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Have you jail broken it or attempted to?
Error 9 generally occurs during a firmware upgrade, and has something to do with a problem with the USB connection to your device that is causing it to unexpectedly disconnect when syncing.
It can be a hardware problem e.g. if the dock/lightning flex is water damaged or something.
Do all the basic stuff first:
  • Reboot your computer and try to restore again.
  • Use a different USB cable and port.
  • Check for dirt/junk/pocket fluff etc. in the lightning connector which could be preventing it connecting properly.
  • Disable any firewalls or security software which may be preventing access to the Apple servers.
  • Try restoring using a different computer.
You need to provide more specific and background info if you need more help.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
no jail broken
do not attempted to do that
door
Hi
Uninstall iTunes and reinstall from Apple direct website https://www.apple.com/uk/itunes/download... and step 2 use a different lighting cable .
And it should fix it and if it doesn't work it's a problem with your device
Voeg je antwoord toe
usup wheelchair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 178
