Ga door naar hoofdinhoud
The HP ProBook line of business laptops was released in April 2009, aiming to be a lower cost to HP's EliteBook lineup.
241 Vragen Bekijk alle
Will I lose my files if I hard reset my pc
I've been reading about this hard reset procedure as a fix for “black screen of death” by simply removing your battery, charger and whatever peripheral device you have connected, by hold the power button for 60 seconds then plug in the charger and switch on your computer.
But I have to ask if I do this will I lose all my files because I don't have them backed up…
Is dit een goede vraag?
Score 1
1 Opmerking
This question was migrated from https://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If the system is properly turned off you won’t loose what is stored on your SSD or HDD drive disconnecting the battery.
Was dit antwoord nuttig?
Score 2
You probably won’t lose all your files because removing the battery doesn’t affect the nonvolatile storage of your hard drive.
That being said, if your computer is giving you issues, it is always best to have a data backup just in case.
Voeg je antwoord toe
Ebahi Agoni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 131
