Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Vragen Bekijk alle
My grandmother’s phone is acting erratic
My grandmother’s phone is glitching weirdly like the apps on the phone screen sometimes out of nowhere flinch or move for a 1/4 sec and when she gets a notification it does the ding sound but then it repeats like din- din-di-di-di-d-d
pls help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It could be hardware related. But to rule out software issues,you can back her phone up to iTunes and save the picures.
First make sure it’s up to date. It could simply be a bug in the operating system(iOS) that perhaps was fixed in a newer update. Try this first through settings,general,software update. If this doesn’t work…..
Now you can reset all settings to see if that works. If not-
Then you can factory erase/reset the iPhone. This can clear software glitches causing this.
then set it up as new temporarily to see if it fixed the issue. If not,you could try a software reinstallation through iTunes.This is more likely to fix software issues.
If nothing works,it sounds to be hardware related. If it’s under its 1 year warranty still or has apple care(probably not), you could take it to apple. But otherwise it’s hardware related.
AGAIN,BEFORE ERASING A PHONE YOI WANT TO BACK IT UP.
Was dit antwoord nuttig?
Voeg je antwoord toe
Brayden S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 46
