Ga door naar hoofdinhoud
De Motorola Moto Z3 Play werd uitgebracht in juni 2018. Hij heeft een 6 inch scherm en een niet-verwijderbare Li-Ion 3000 mAh batterij. De camera achteraan is 12 MP en de camera vooraan is 8 MP. Modelnummers XT1929-3, XT1929-4 en XT1929-8. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
Screen replacement causes digitizer to not work
We are a repair shop and we have tried replacing the screens on this model a few times xt1929-17 and every time the digitizer doesn’t respond on the new lcd has anyone experienced this issue or come up with a fix?
Is dit een goede vraag?
Score 10
Voeg een opmerking toe
2 Antwoorden
I am also experiencing this issue! The digitizer stops responding once you turn the phone off and then back on… it’s a little annoying to say the least. Any guidance on this would be awesome!
Thanks
Was dit antwoord nuttig?
1 Opmerking:
I’ve researched and asked local shops as well most have just blamed it on the current quality of the parts on the market being low. Are shop has suspended repairs at the time do to the large warranty rate of the XT models
door
You have to do a hard restart. It’s the only way I’ve found to do it.
2 opmerkingen:
Could you clarify how you did that? I had the battery cable disconnected, replaced the screen with no problem, and turned the phone on without issue. The problem is that the touch doesn't register, no matter how many times I fiddle with the battery. This was a straightforward, easy fix up until this point.
door
When he says hard reset, he's likely referring to a factory reset.
I haven't replaced the screen on this device yet, but I plan to soon. I'll let you know if I run into this issue and have I might fix it.
door
Voeg je antwoord toe
Mike Henry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,316
