Ga door naar hoofdinhoud
Tv does not turn on at all
my samsung tv doesnt turn on as soon as you plug it in it blinks 2 twice tree times then stops and if i press the power button it just blinks once. tv model is UN40D6000SFXZA
i asked this a few days ago but could not open up the tv due to some stuck screws so now i have and also took some pictures.
Did a few things after that: disconected main board from power board and the backlight did turn on, also while everything was connected i touched the top on the main chip(SDP1001) on the main board and it was pretty hot to the touch.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@ishen all of this “disconected main board from power board and the backlight did turn on” and the heating up of an IC would make me replace the main board. A failed main board is consistent with your TV’s issues.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
yea i look like ill have to find a replacement for it then thanks for the input
door
Voeg je antwoord toe
Juan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 118
