Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Vragen Bekijk alle
Looking for 8.6mm screw for Antenna/Camera cable retainer - missing!
Hi!
I just bought a “refurbished” mid-2012 15” 2.3 GHz A1286
Problems with the left screen hinge loose, and random crashes and freezes, more frequent on moving.
Opened up the case, dug down, found, in addition to loose hinge screws, the antenna/cable retainer missing an 8.6mm screw and ground tab floating loose.
Where can I get the screw? I temporarily “borrowed” one from the Airport/Bluetooth assembly.
Thanks so much, everyone!!!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
See if you can find the needed screws here MacBook Pro Unibody 15" Mid 2012 - Screws
Your other option is to get the full screw set here: MacBook Pro 15" Unibody (Mid 2010 - Mid 2012) Screw Set
MacBook Pro 15" Unibody (Mid 2010 - Mid 2012) Screw Set Afbeelding
Product
$49.99
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Awesome! they apparently have pair of screws for the assembly in stock (recycled), but are in the UK, half a world away ~ if no one in the US has the parts, iʻm ordering from them. their website is really efficient, at least, their search engine is.
door
Het nuttigste antwoord
Drop by and introduce yourself to the old independent Mac repair guy that you find on Google.
Ask
if he has a spare screw.
If the hard drive I/R cable hasn’t been replaced, do it. Then use 3M Extreme mounting tape to prevent future damage.
UPDATE
Image of shipping envelope was here but deleted for security purposes as your address and name were on it.
Ships out Monday
Score 4
10 opmerkingen:
great idea! iʻll be upgrading to a 1TB SSD in a couple of months (iʻm on a very limited disability income right now ~ actually, iʻm hoping to use the computer for a one person stage lighting/sound design company to get off disability). when i get that, iʻll change out the cable as well. by chance, do you have a spare screw, cable and SSD for sale?
door
iʻll check them on line. problem is, i donʻt know the diameter and pitch, and whether there are other special requirements (material, treatment, etc.), so i was planning on forking out for OEM.
door
@the_kat Kahana Do I look like an " old independent Mac repair guy"? Well. that's exactly what I am. Yes, I have your screw, cable and SSHD. But you accepted the worst answer given. My email is listed in my profile.
Wait, the 15" does not need the cable, that's on the 13", sorry.
door
@the_kat Email me your address and I will mail you the screw.
door
omg youʻre awesome!!!!
door
5 commentaren meer tonen
You might just try going to Lowes or some hardware store. They often carry metric screws.
Score 1
2 opmerkingen:
They don't offer screws this small
door
Whole Witt the problem as I see it is the way iFixit measures the screws. The 8.6mm is actually the length not the screw size diameter the way it usually is measured. A hardware store would have an 8mm bolt for sure :-) A good camera repair store will absolutely have the right screw :-)
door
Voeg je antwoord toe
Kahana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 154
