Ga door naar hoofdinhoud
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
Samsung Note 4 won't charge
I just got this used phone from my dad and he just replaced the charger in it a couple of days ago and today he handed it to me and basically said good luck and left me to it. However, I’ve noticed that it won’t charge. I’ve tried taking the battery out and putting it back in, and I’ve tried testing the charger on other devices and the charger works fine. The only time the phone will charge is when it is completely powered off and it only charges in quick little flickers. Every second or two it will charge enough for it to make the phone buzz and then stop. I can’t get it to charge at all if it’s powering on or if it’s on and I’ve tried searching all over the internet to see what I can do about it. I figured it’s something wrong with the charging port but I have no money to go get this phone fixed. I appreciate all the help I can get.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
my suggestion is first see if it is the battery problem. instead of purchasing a new one, you should go to your local repair store and check with a different battery if it charges. Most repair stores will have Note 4 batteries just lying around. if problem persists then yes, it most likely is the charging port.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you so much for the advice! I really appreciate you and I'll definitely try that as soon as I am able. :)
door
Voeg je antwoord toe
Arin Turner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 366
