Ga door naar hoofdinhoud
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 Vragen Bekijk alle
What cable is this?
Can someone tell me what the correct name of this dual cable is is? (red arrow points to it)
I suspect it is some sort of antennae connection.
I was replacing a damaged glass front screen and they unfortunately broke - need to know if I can replace them.
Thank you in advance for any help.
Regards,
DLC
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No unfortunately if it's the one on the digi then u need to replace the digitizer, if it's the one in ur fingers then that's for the home button u can replace that one with a new home button flex
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Those are the digitizer cables that transmits the touch inputs of the user. If you broke those, you need a new screen: iPad 5 Screen Digitizer
iPad 5 Screen Digitizer Afbeelding
Product
$44.99
Score 1
2 opmerkingen:
Sorry u beat me by a minute lol
door
Thank you, fortunately I had already bought a screen replacement, and lo, said cables are pre-attached - just hadn't opened the box yet. Thanks much for providing the response.
door
Voeg je antwoord toe
dlcatftwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 66
