Ga door naar hoofdinhoud
Audi introduceerde hun nieuwste (4e) generatie A4-model op de Frankfurt Auto Show van 2007. Dankzij het gloednieuwe Audi Modular Longitudinal Platform - dat gedeeld wordt met het Audi A5 Coupe-model - beschikte de nieuwe A4-sedan over een verbeterde gewichtsverdeling.
Oil indicator does not show oil level
How to fix oil indicator to show oil level
Is dit een goede vraag?
Score 2
1 Opmerking
Jeffrey D Smith what exact year, model and engine size is your Audi?
door
Voeg een opmerking toe
6 Antwoorden
Filteren op:
Het nuttigste antwoord
For future readers, my A4 B8 had the same issue, it ended up being that the electronic switch in the bonnet catch was sticking and not detecting that the bonnet is opening. A tell-tale sign in that the “hood ajar” icon won’t be on the dash and hitting the latch with a hammer will unstick it. This happens because the car checks if the bonnet has been open before reading the oil level.
Was dit antwoord nuttig?
Score 4
May be sensor is the issue or engine’s oil pressure . Also caused the oil lines are blocked by debris . Have you check the oil level with the dipstick ?
Score 1
does it fail to read all the time or just certain times? the sensor is a thermal level sensor so will struggle to read on an uneven surface or bumpy surface whilst moving or when the oil is too cold. if it is a B8 ea888 engine is doesn't have a dipstick unless an aftermarket one has been fitted.
2 opmerkingen:
it fails to read and it does not have a dipstick.
door
what engine is it? there is a small cap on the 4 cylinder petrol engines (there probably will be on diesels too) at the front of the engine in front of the dephaser that you can buy a dipstick in to check the level, the electric one won't show an oil level if it is full, only if it starts dropping the level, the 1.8 &2.0 petrol engines will show to level all the time if its slightly low even when the car is cold and just the ignition on, as long as its sensor is plugged in and not damaged although there pretty tough to break. again not too sure about the diesels. I currently have the A5 with the 2.0T engine and that can go an age without showing any level if its topped up to the correct level it just says its unable to show it at this time or something like that.
door
Sorry to come back on the issue like that, but I had to drop a comment to say THANK YOU!
I had the same issue for a year. The mechanics couldn't figure out anything.
After reading this post, I noticed my bonnet sensor didn't work either. I removed the locking mechanism (a real pain to do), removed the switch, cleaned it with both WD40 and contact cleaner. After about 5min, it got back to work!
The car checked the oil level and the alert was gone. GONE!
You guys saved me a lot of time, money and headaches.
Hoping this can help someone.
I bought a dipstick on Amazon for my Audi A4 2.0T Quattro. I had to cut the dipstick ring hand holder in half so it didn't hit the hood when closing it. Then I added a half quart of oil in the engine. Then when I went to check the oil, first with the dipstick, then on the MMI display to see if they matched. The MMI oil reading said it was unavailable at this time. I wasn't sure why it wasn't reading it. Was it because I installed the new dipstick or because I added oil. It's a newly purchased used Audi A4 2.0T Quattro and this is the first time I needed to add oil. Anyway, I was very disappointed that the MMI display wasn't working. I thought maybe the new dipstick was interfering with the reading sensor. But to my relief after a few days, the MMI displayed the oil levels like it did previously.
I've the same issue.
It is related to a broken switch into front bonnet latch mechanism.
It is not sold separately but if you want to replace it, you are forced to replace the whole mechanism
a possible work around is to follow the latch's wire
after around 1 meter there is a connector
unplug it and create for few seconds a short (i.e. by few cm of eletrcical wire )
As double check give a lock inside the car: you will see the open bonnet
warning light in the dashboard
Then remove the short and plug the cable again as before and close the bonnet.
Finally car will detect the correct oil level
Voeg je antwoord toe
Jeffrey D Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 122
Altijd: 9,385
