Only prints 1/2 the document - Epson L360
My printer is just printing half of the document. The other half of the paper is blank.
How do I fix this?
Please Help
Is dit een goede vraag?
How do I fix this?
Please Help
The article on this website might be able to help:
https://imagescience.com.au/knowledge/my...
To sum up the article, it could be:
A messed up USB port on your computer (you can just use a different port).
A problem with Print Spooler on Windows PCs (It shows steps to reset it).
A messed up USB cable (you’d have to find out if it’s easy to get a new cable and just switch it out).
If you have a Mac resetting the print system is an option.
All credit goes to Jeremy Daalder.
Good Luck.
Was dit antwoord nuttig?
USB port change solved the problem of printing only few pages of a document
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 2,844
2 opmerkingen
Can you explain a bit better what you mean here a bit more on the details would help. Does the printer report an error? Does it make a grinding noise? Did you try using a new ink cartridge if the printer told you it was low.
> Is the page not fully printed and which side is missing Left or Right or Top or Bottom?
> If its a multi page document, does the pages fully printed you're just missing a few pages?
door Dan
My printer Epson L360 printed only few pages of a document.. So I have to print a couple pages only at a time. For example for document with 10 pages, I need to print 5 times, printing 2 pages in each print. As per the reply given here, I changed USB port of the printer cable, it worked well. Thanks for the reply
door Karuppanagounder Somasundaram
