Ga door naar hoofdinhoud
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 Vragen Bekijk alle
What size of tap to clean headbolt fhreads on the 4.6 motor
What size of tap used to clean headbolt threads on the 4.6moror
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Windy Martinez  just for completion sake. The thread size is M11x1.5
2004 and after uses a M11x2.0
Was dit antwoord nuttig?
Score 2
One other point. You really shouldn’t clean bolt holes with taps. The problem is taps can cut and damage threads. There are clean-out taps that are made specifically to clean threads. Much better option. They usually come in a kit that will cover both metric and standard sizes.
Voeg je antwoord toe
Windy Martinez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 61
