Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Convert 1st Gen iPhone to iPod touch
I have upgraded to an iPhone 3G but still have my 1st Generation iPhone. AT&T switched out the SIM card. My question is can a first generation iPhone be used as an iPod touch for Apps, Games, Wifi, etc. I want to pass this on to my kids. I tried the direct approach but my computer won't recognize my iPhone without the SIM card and AT&T won't sell just a SIM Card without an account.
Thanks
Is dit een goede vraag?
Score 1
1 Opmerking
I appreciate the answers below.
FYI, simply putting in a new sim card didn't work. The phone must be activated. One can not activate a new sim card without starting a separate AT&T account for the phone (I don't want to spend the money).
I bought and tried a jailbreak program which was an miserable experience (a huge waste of time that ended in failure).
I re-read the advice from BAC. I was trying to avoid switching the sim card from new phone to old phone for fear that something will go wrong with my new phone when I put the sim card back in the new phone. But the apple support doc does suggest this is okay but doesn't state it directly.
So, the question is, if I take sim card A, out of iPhone B (3G), put sim card "A" into original iPhone A (1st gen), activate iPhone A, take sim card A out of iPhone A and put it back into iPhone B, will iPhone B work as normal.
I will post this as a new question.
Thanks
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
@bac, I've lost a few phones, and AT&T has given me several new SIM cards at no charge. I simply told them I planned to recylce an old phone.
Was dit antwoord nuttig?
Het nuttigste antwoord
Jailbreak and unlock would be the way to go, however some things would not work, such as Google maps, which is known not to work on sim-less iPhones. Use a tool like BlackRa1n to jbreak.
Score 2
1 Opmerking:
Thanks
door
You can buy a SIM Card here.
Score 1
1 Opmerking:
Thanks
door
you should be able to use your old iPhone without SIM card, as if it were like an iPod touch
I did this with my 3G when I first got my 3GS - for a while my kids were using the old 3G with all my same apps only just using WiFi, while I used the original SIM card in my new 3GS (I've since sold the old phone).
the key is that the old phone must be left activated. In other words, if you do a complete restore of the old phone to wipe it clean, it will not even operate as an iPod until you activate it with your SIM card (like you did when you first got it). but after that it's ok to use without SIM card.
*EDIT* - I just found an Apple support document that shows a difference between original iPhone and later models regarding this issue.
according to the doc, the 3G and 3GS will operate without a SIM as I have described above, i.e. once activated you can remove the SIM card and it will work as if it were an iPod touch
However the original iPhone (which is what the OP has) behaves differently.
it says to use the iPhone without active cellular you need to have the original SIM card it was activated with installed *even if the SIM card is now inactive*
so I think a solution (without jailbreaking) for your original iPhone would be to somehow get AT&T to switch your cellular account to a new SIM card (your dog ate your old SIM card, perhaps?), then leave the old now-inactive SIM card in the original iPhone? unfortunately this would not be a zero-cost method...
Score 1
1 Opmerking:
Thanks
door
Additionally, you can just restore it and jailbreak it. :D That's what I did with mine to turn it into an iPod touch. Just use a jailbreak like Spirit and you should be good to go. The key is to get it hacktivated; iTunes then won't care what the phone looks like.
Voeg je antwoord toe
drprice zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 30,406
