Ga door naar hoofdinhoud
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
How do you expose the lens/sensor to blow dust off?
I can open the case but how do you get the lens/sensor exposed to blow the dust off the lens and/or sensor?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You have to remove the lens assembly from the camera then open it to reach the sensor.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks for the reply, but how do you remove the lens assembly and open it? Is there a procedure/exploded view? from Canon?
door
Canon service manuals are pretty hard to find but maybe oldturkey03 could check if he can find it ?
The only tutorial I can find is how to replace a bad LCD panel on a A590:
http://www.youtube.com/watch?v=dfXG1OAgc...
door
Se if this will help to get the lens cover off Canon PowerShot A590 IS Flash Assembly Replacement
1 Opmerking:
Thanks, but this procedure does not continue to lens assembly removal/opening. Is there a continuing procedure available?
door
Voeg je antwoord toe
george zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,403
