Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Vraag afgerond
buy a broken iPhone 4 on eBay in order to repair it?
i would like to ask if its a good idea to buy a broken iPhone 4 on ebay, in order to repair it?
Because I've spotted out such a broken iPhone 4.
Is dit een goede vraag?
1 Opmerking
Are you sure of what's wrong with it? Are you sure you can repair it?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
and just like mayer says, unless you know for sure what needs to be repaired you may get in over your head (and wallet). Consider cost of new parts and your skill level. It is amazing how many times we add to the repair by causing additional damage during dis-assembly. Good Luck
Was dit antwoord nuttig?
Score 3
I'll get a water damaged iPhone i guess. if I got the time, I'll do a (hopefully successful) water damage repair guide for iPhone 4, nice ? :D
2 opmerkingen:
I'd say (thanks to recent experience) that water damage is russian roulette. A lot of people are advertising as water damage but what they don't say is how long ago and what type of "water" it was. I've had 2 out of 4 turn out to be damaged beyond financial repair. If you want to buy damaged and repair, then go for a broken screen or look at feedback/recent goods sold...
door
even if the logic board seems to be working (like able to connect to iTunes like usual) and do this vibrator thing when it gets plugged in?
door
After searching completed auctions for broken iPhone 4s on eBay it appears that the median price is around $300 (US). If you get a good deal and are confident that you can repair the issue then it may be worth the gamble. However, I'm guessing it won't be worth it.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 5,404
