Ga door naar hoofdinhoud
Uitgebracht op 15 september 2008 10,1 megapixels, 5x optische zoom, 3,5-inch LCD, HD-filmopname
Camera Memory stick locked
Memory stick is locked. not able to shoot photo, nor i can delete photos.
Is dit een goede vraag?
1 Opmerking:
Is there a lock switch on the stick?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
If you’re using the older style of memory card called the Memory Stick Pro, you should have a lock switch on the back of the card that might’ve accidentally gotten switched on. They look something like this (a red part of the switch will show if the lock function is turned on):
Afbeelding
However, if you’re using the newer Memory Stick Duo or Memory Stick PRO Duo card, it doesn’t have a lock switch, and that might mean that there’s something electrically wrong with the card or camera. If you have another memory stick you can try in the camera, you can check and see if the error still shows up.
Was dit antwoord nuttig?
Voeg je antwoord toe
Umesh Kawalkar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 976
