Ga door naar hoofdinhoud
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
20 Vragen Bekijk alle
What is the issue?
what I noticed with my radiator fans is that it would run constantly on high if the ambient air temp sensor isn't plugged in but if I plug it in the fans don't turn on not even during cold start. All of the relays and fuses are operating but can't find the issue.
Is dit een goede vraag?
2 opmerkingen
@willx do the fans eventually turn on while you run the engine? What exact year and engine size is your Passat?
door
No they won't and it's a 2015 1.8
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would take it to an AutoZone and get a free computer readout to try to isolate the problem.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Will zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 147
