Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Zif HDD connector type
Hi All!
The HDD Zif connector in my iPod has cracked and failed. Does anybody know what type of connector it is? It looks to have 40 pins but I don’t know what its called or who makes it so I am struggling to order a replacement. I have removed the old connector and all of the pins are good under it.
EDIT:
Below is an image of the iPod’s LCD connector. This is identical to the HDD connector which is missing from my board:
Thanks,
Oliver
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here’s the part:
Apple part # 632-0259-A
https://www.powerbookmedic.com/iPod-4th-...
iPod 4G Hard Drive Cable
Here’s how to install it:
iPod 4th Generation or Photo Hard Drive Replacement
Attaches hard drive to logic board Afbeelding
Product
$9.99
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hi mayer,
Thank you for your reply!
I should have made my question a little clearer, it’s not actually the HDD ribbon that has failed, but the Zif connector on the iPods logic board.
do you know where I might be able to get a replacement from?
I’d rather not replace the logic board as it’s a U2 special edition that I have.
Thank you,
Oliver.
door
Oliver
from what i have been looking at its a zif connector and if this is broken a new ziff connector will need to be re-soldered onto the logic board...
same boat myself. I know this is some time after but i always still would like to know the anwser.
Dane
door
Voeg je antwoord toe
Oliver zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 1,200
