Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Vragen Bekijk alle
Early 2009 Display Assembly on Mid 2009 system
Hi,
I was wondering if the display assembly from a late 2008 to early 2009 would fit on my Mid 2009 MacBook Pro 15” 5.4.
The connectors seem to be identical.
Thanks for your help :-)
Is dit een goede vraag?
4 opmerkingen
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
door
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
door
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Arne Büsing  without knowing the actual panel number and only going by the information you gave us it looks like it is compatible with the following:
MacBook Pro 15.4" 2.0GHz Core i7 (A1286) - Early 2011
MacBook Pro 15.4" 2.2GHz Core i7 (A1286) - Late 2011
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1286) - Late 2008
MacBook Pro 15.4" 2.4GHz Core i5 (A1286) - Early 2010
MacBook Pro 15.4" 2.53GHz Core 2 Duo (A1286) - Mid 2009
Your panel should be one of these models
LP154WP3, LP154WP4, LP154WE3-TLA1 or LP154WE3-TLB1 if so, it’ll fit.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Hi oldturkey03,
thank you for your answer. I apologize for not providing more Information.
the Partsnumber of the assembly is, as far as I know, 661-5091. the serial # of my MBP is W894201E7XJ
Thanks !
door
Arne Büsing looks like the full assembly is only compatible up to early 2009
door
Your machine is the
Apple MacBook Pro "Core 2 Duo" 2.53 15" (SD) Specs
Identifiers: Mid-2009 15" - MC118LL/A - MacBookPro5,4 - A1286 - 2324*
door
Voeg je antwoord toe
Arne Büsing zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 136
