Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
THINKPAD T520: Topprestaties en draagbaarheid.
Computer says my password is wrong?
I stopped using my computer for a few months, and when I tried to log in again it says my password is wrong. I know for a fact it isn’t wrong because my other computer that is connected to the same Microsoft account logs in fine. It isn’t because my number lock/caps lock, as it still doesn’t work when I toggle them on and off. In addition, my wifi has changed so this computer is not connected and I am not able to connect it unless I can log in. It’s a pretty old computer but has worked fine for years. Any help would be appreciated :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Log onto your MS account via phone, update password. Once in your computer, look at your user settings then set it to "Sign in with a local account instead" to allow you to sign in without a MS account.
This should work, regardless of updates. If not you may have to "refresh Windows" (save your files first) to restore back to factory installation.
Good luck.
Was dit antwoord nuttig?
Voeg je antwoord toe
Coral C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 887
