Ga door naar hoofdinhoud
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 Vragen Bekijk alle
I see a black screen and arrow while installing new os x
hi
i installed a new segate hard drive and tried to install os x panther 10.3, i can see the apple black logo and running weel in the bigining and after some times the screen become black and see a arrow in the middle and stops installation. what i can do for fixing it . any body can help me
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I think it's looking for a hard drive to install onto. From your system installation disk, go to the second screen pull down menu to Utilities > Disk utility. Select the drive on the left and format it. Now quit Disk Utilities and see if you can continue with your system installation.
UPDATE
Start up from your system installation disk by inserting the disk and restarting holding down the "C" key, go to the second screen pull down menu to Utilities > Disk utility. Select the drive on the left and format it. Now quit Disk Utilities and continue with your system installation. When finished, restart from the hard drive and register your software. Now go to Software Update under the Apple in the upper left hand corner, download and install the updates from Apple.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
when i insert and hold the c key i can see only the apple logo and near to bottom a running weeland i cant go to the next screen.
door
Reseat your RAM. Is the installation disk one that came with your computer? What color is it?
door
thank you for your reply. i have only the panther insallation disk. how can i go to the system installation disk. can you explain step by step.
door
If this gray disk is for another machine, it will not work for you. You'll need a retail installation disk.
door
hi mayer
the colour of the disk is gray
The colour of the disk is gray, i have two disks, and i cant find any Ram fixed in the slot. i think it had built in 512 Ram on board
Voeg je antwoord toe
Paul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 490
