Ga door naar hoofdinhoud
iPhone 7 stuck on apple logo after screen replacement
I first replaced the screen and got a boot loop error.
When I connected the old, broken screen it worked fine and booted properly, so thought it was the new screen that was faulty.
I ordered another replacement screen and did the replacement but afterwards the setup just stayed on the apple logo indefinitely. I thought this screen was faulty as well so reconnected the original broken screen but the same thing was happening with that.
I read through a few forums saying it may be the camera flex cable that is broken, so I disconnected that and there was no change, still staying on the apple logo.
I have now bought another camera flex cable to double-check if that’s what is causing the error (I may have broken it during one of the replacements), but no success.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
I had this happen on an iPhone 7 Plus that I was working on. Double Check the connections from the screen going to the motherboard. Apparently one of the connections on the screen was not seated correctly and was causing the phone not to boot.
Was dit antwoord nuttig?
1 Opmerking:
I have pressed down reasonably hard on all the connections but that hasn't seemed to work.
door
If all the cables are connected correctly, I’d try a new front camera flex just to be sure. 7s boot loop for pretty much any little issue, just try a couple things if you have parts around
1 Opmerking:
I have already tried this with no success.
door
Did you disconnect the batter before repair and connect the battery last after the repair? This can happen if you have damaged the home button flex. Maybe the first screen was faulty but when transferring components to the new screen then you may have damaged it the home button flex. Another reason could be you somehow damaged the battery when repairing the screen however that isn’t very likely to happen.
1 Opmerking:
As I did the transfer between screens a few times I may not have disconnected the battery every time.
Also, before I bought the newer replacement screen I did manage to get the original screen to work without the home button flex connected, so I don't think it is that.
door
Voeg je antwoord toe
James Lloyd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 134
