Ga door naar hoofdinhoud
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
I need a replacement LCD touch screen is this even possible
I need a replacement screen for my mfc j6920dw is this possible as I cant find one anywhere
Is dit een goede vraag?
Score 1
2 opmerkingen
Hi Chris
DO you have found a solution for your touch screen ?
I have the same problem, I need a replacement LCD touch screen
Thks
door
Has anyone found a touch screen replacement yet?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @chrisw15 ,
I think that this is what you’re after.
The part number is LED448001 found in this printer parts list (scroll to p.17).
There may be other suppliers which suit you better. Just search online for LED448001 to get results
Was dit antwoord nuttig?
Score 3
Check this page from printcopy.info to see all the parts you might need. The referenced part above appears to be the Touch Panel Assembly only, and there is an LCD also just in case your LCD is cracked too.
Score 1
Voeg je antwoord toe
Chris Wheelans zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 5,524
