Ga door naar hoofdinhoud
Verschenen op 22 september 2017. Model A1864, A1897. Beschikbaar als GSM of CDMA, met opslagopties van 64 of 256 GB. De beschikbare kleuren zijn goud, zilver en spacegrijs.
Overheating and drainage fast.
Hello,
i have a question.
I run an repair shop and i repaired like dozens of phones.
i recently refurbished my own iphone 8 plus device to make it look new.. but now my phone is overheating entirly but at the power button it is even warmer.
the phone also lose 1% every minute when using it.
-housing replaced
  • original battery
  • Oem screen
Is dit een goede vraag?
Score 3
1 Opmerking
I got the same problem :(
Have you fixed it?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Bad Tristar chip on the motherboard. Microsoldering required to repair it.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Checked chip.
Its fine.
I notice when i am using the phone with on spotify and when using sound true top speaker the phone is getting hot.
Any solutions for that?
door
So,
This is the place where it heats up.
https://ibb.co/8Y5zDpG
On the front and at the power button it heats. The most i feels like 40c back site is little warm.
Rest of the phone is not as warm as the top
door
Did you try a new battery? Also go into your settings go to battery and than battery health. If its below 82%, I recommend a new battery anyways.
2 opmerkingen:
Changed housing,
Changed battery
Changed screen.
Everything works normal...
Just special apps like spotify , gaming its getting hotter as usual... and then the battery drains way faster.. like half of the time as before
I am running ios 12.2. i refurbished this one and i put my back up on this phone and had to update it. So i dont know if it was befoee the update aswell.. thats the problem.
Is it possible that it could be?
-faulty screen
-proximity sensor?
- copy power flex
- copy dock connector
door
Maybe just backup your phone and then do a DFU restore to see if that fixes it.
door
Voeg je antwoord toe
glennjacobs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 851
