Ga door naar hoofdinhoud
De HP Officejet 6600 Inkjet-multifunctieprinter is een 4-in-1 apparaat waarmee je kunt printen, scannen, kopiëren en faxen.
Sheet feeder not pulling paper into machine
Drop down sheet feeder intermittent. Makes grinding noises. Does not pull paper into printer. Returns error message to load paper.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Paper Tray Rollers
  1. Turn off and unplug your HP printer. Pull out your printer’s paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
  2. On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
  3. Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
  4. Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Was dit antwoord nuttig?
Score 3
Using some 85% isopropyl alcohol wipe down the feed rollers see if that solves it.
Voeg je antwoord toe
Savarese Family Calendar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 2,062
