Ga door naar hoofdinhoud
Manufactured by Acer America Corporation that is used nationally with a growing popularity by their various devices that are offered for business and personal uses. Was released in November 2015.
9 Vragen Bekijk alle
The chromebook will not turn on
i have the cb3-532 acer chromeboob 15 model. the unit displays message os has 1% and turns off.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Does the power indicator light up when plugged into AC? Find this light typically next to where the charging port on the side of the chromebook is located. If not there is a likely a problem with the AC power supply or the charging port inside the chromebook.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
larry mitchell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 386
