Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
recently replaced digitizer issuse
So, i recently replaced a digitizer not from ifixit.
and it worked for a few seconds but stopped working completley after a few good seconds home button was not working too. i opened up the mini again and inspected it. No issuses whatsoever and put it back on. digitizer and home button is not working at all. should i sell it for parts?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Did you have the same issue before replacing the digitizer? I suspect that replacement digitizer is defective, try another known working digitizer to confirm.
If issue persists, then you need someone with micro-soldering experience to fix as this is board related.
One thing I want to point out that the Mini/Mini 2 replacement digitizers are notorious for ghost touching (iPad activates itself erratically), make sure you cover the bottom strip near home button with Kapton or any ESD tape.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
the old digitizer has the ribbon cable ripped out making it useless
door
Sins you didn’t buy it from ifixit i am assuming the quality was bad and thats why this happend. Do you still have the old screnn if you do try to see if it turns on. Is it recognized by iTunes?
3 opmerkingen:
the old screen is done beacuse i got it the ipad for free and the ribbon cable is gone for the old digitizer
door
it is recognised my itunes
door
Okay so just buy a new one from here and it should work
door
Voeg je antwoord toe
Zander Castillon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 72
