Ga door naar hoofdinhoud
Repair guides and troubleshooting for the EasyNote TJ65-CU-030GE, a 15.6" budget laptop by Packard Bell.
17 Vragen Bekijk alle
No powering on, not even a light
EasyNote Te
Have tested the power cable (friends) so not the cable’power.
Have taken the battery out, held switch down for 20 sec’s then plugged in the cable, still no joy, not even a light.
Is dit een goede vraag?
1 Opmerking:
it may be a software or internal computor issue try go getting it repaired by a person licened to do so to avoid damaging your pc any further
door
Voeg een opmerking toe
2 Antwoorden
This is internal damage, The Display Cable might be loose or damaged, you will probabally need a professional to remove the screen. Its easy to put the cable in but it is also very easy to destroy the cable.
Was dit antwoord nuttig?
Yes i did so,but still is not powering or showing any light
Voeg je antwoord toe
Alan Barber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 2,032
