Ga door naar hoofdinhoud
SodaStream Source is een nieuwe manier om thuis frisdrank te maken, waarmee je je drank kunt personaliseren en alleen de drankjes kunt maken die je wilt, zonder alle extra flessen.
22 Vragen Bekijk alle
Why does water squirt everywhere when carbonating water?
I have been given a soda stream as a birthday gift which sprays water everywhere when you try and carbonate water. There is a small red/orange peg about 5mm long loose in the box, I’m wondering if this could be the culprit? I don’t have the receipt as it was a gift and the purchaser doesn't’ either and doesn’t live in the same country as me. It seems a waste to chuck it but it’s of no use to us in its current state. Any advice?
Is dit een goede vraag?
Score 6
3 opmerkingen:
I'm wondering if it has to do with how much carbonation is in the charge bottle. Mine only does this when the charge bottle is getting low. But it's extremely annoying and messy and wish we got answers @sodastream.
door
Same problem, I have double-checked everything. Only one thing left to do. Send it back
door
This problem after several years of faultless use has appeared
Using glass bottles in an expensive version.
Can only imagine it’s the seal between the sodastream and the top of the bottle.
Perhaps need to exchange the seal but how?
Any instructions?
door
Voeg een opmerking toe
1 Antwoord
If your SodaStream Source is leaking during carbonation, see the SodaStream Source is Leaking During Carbonation problem page. Common problems include the carbonation bottle not being inserted in a completely upright position, not fully attaching the bottle, and using a starting liquid other than plain water or unflavored carbonated water.
Was dit antwoord nuttig?
4 opmerkingen:
This answer does not fix the problem.
door
I agree, it does not fix the problem
door
This is the stupidest answer that resolves nothing. It’s the o-ring and neck holder. But how do you get the parts?
door
Useless answer. We all assume that the instructions shown in the guide have been followed. Same issue here. In my case, the water bottle is correctly inserted and pushed up. When empty, the plastic claws around the nech hold the bottle tightly and this doesnt move, no up-down play. Once filled with water, the claws cant even stand for the weight and the bottle becomes loose, an up and down play appears, creating a gap where the water spills through very violently. A real mess. The device is clearly faulty, needs replacing.
door
Voeg je antwoord toe
Alex Richardson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 276
Altijd: 15,056
