How to reset instrument cluster on 2010 isuzu dmax 4wd?
Currently none of the gauges work but the warning lights work. Is there a way to fix this?
Is dit een goede vraag?
Hi,
Did you check the fuses in the instrument panel fuse box to see if they are OK, you didn’t say?
I don’t know your vehicle and couldn’t find a manual for your year model D-Max but found one for a 2012 -2015 D-Max which shows 2 fuses with “meter” designations.
Worth a look anyway to check if yours is the same or similar and if they’re both OK or not.
Here’s an image taken for the manual showing the 2 fuses.
(click on image to enlarge for better viewing)
Was dit antwoord nuttig?
fuses are good .. have to test another panel board to see if the stock is faulty. and found out it was. so we remove the stock board trying to repair it. hope reheating the circuit will do.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 73
Altijd: 7,533
