Screen wont sit flush
Hello. I changed the charging port and battery and now when i put the screen back on, in the down right corner it doesnt sit flush. Its raised a bit. Please help
Is dit een goede vraag?
This is usually caused by how the screen flex cables are aligned. Take a look at the flex coming from the screen and notice that there is a silvery “chip” on the flex. If it isn’t aligned properly, it will impede the way the screen sits on the housing.
Was dit antwoord nuttig?
Where is the silvery chip ? I cant find it. Could you send me a photo of it please ?
oh, i know what chip. It seems that the chip from my replacement screen is a bit bigger than the one on the original one. What should i do with it ?
The arrow of the "Start Guide" practically points to it :>). Sometimes it just needs to be moved over a little bit until it rests in the opposite "hole" properly.
Did you use this because without it, it can cause it to pop up a little. iPhone 7 Display Assembly Adhesive
No I didnt but i dont think its the solution. I noticed that the silvery chip on the flex cable is a bit larger than the one on the original screen. I think it doesnt fit in because its too big. What should I do about it ?
Where did you get the screen from ifixit?
Ok if you didn't get it from here then get this. iPhone 7 Screen iPhone 7 Display Assembly Adhesive
OK, thanks :D
Keep me updated on how it goes.
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 205
