Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De a7R II (modelnr. ILCE‑7RM2) is Sony's revisie uit 2015 van hun spiegelloze systeemcamera met full-frame sensor en verwisselbare lenzen.
Immediately after turning camera on - camera error..
Immediately after turning it on, it clicks up and down the shutter on the display and in the viewfinder a camera error is displayed. Turn off the power then turn it on. Tell me what could be the problem. Can I diagnose the camera on my own? Tried to shake the camera a little does not help
Is dit een goede vraag?
2 opmerkingen:
any error codes? what is the exact message? do you have a lens on the camera?
door Deel
No codes. message "Camera error.Turn power off than on." no matter with lens on camera or without.
This is almost a new camera. maybe 100 shots. Owner did't use it for a couple of years . Then he decided to sell it. everything was okay .he checked it. went to the meeting with the buyer on the bike. Turned on- there was this error.If a memory card is inserted, the red light flashes for a few moments.
recharging the battery from power bank works.
I'm not an expert, but it looks like the motherboard is working.
Inside there is a small ML621 Rechargeable 3V battery . May be dead.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Shutter is stuck it seems. Follow this sony guide: https://us.community.sony.com/s/question...
Was dit antwoord nuttig?
1 Opmerking:
tried. didn't help.the sensor is not skewed like on youtube video,moves as if normal
door Deel
Try to reset camera to factory default If possible. Remove battery and then press and hold power button for 10 second and then reinsert battery.
Different camera has different way to reset check manual.
1 Opmerking:
unfortunately does not help. Nothing happens
door Deel
Voeg je antwoord toe
Yuri Mironov zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 39
Altijd: 2,064
