How to repair keyboard keys?
Hello. Im facing difficulty while using few keys on in laptop keyboard. Few keys like X, 3,7 need to be pressed hard to 2-3 times to work. Other keys are working fine. What could be the issue? How can I repair this issue? Thank you.
Is dit een goede vraag?
4 opmerkingen
Did you spill soda on the keyboard? It sounds like you need to wipe out the gunk that was left behind. It's an easy enough fix, you will need to make sure the device isn't plugged in and then drain the remaining voltage buy holding down the power button.
door Abraham Luna
No nothing happened of soda spill incident. I once opened my laptop to change hdd. It's happening since then.
door Roshanlal
Thank you so much.
door Roshanlal
I got my keyboard replaced by Authorized Dell Executive. Its been working smooth since then. Thank you for your help.
door Roshanlal
