Ga door naar hoofdinhoud
Isuzu introduceerde de vijfdeurs Isuzu Rodeo in 1990 in de Verenigde Staten voor het modeljaar 1991.
Driver window and power locks not working
98 Isuzu rodeo power window works sometimes, when not working the switch makes a buzzing sound. It’s only the driver side window. All other windows work all the time. Also the power door lock works sometimes and makes a buzzing sound when not working.
Replaced the master control switch and the driver side window does the same and now power lock button just makes a clicking sound. What should I try next.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@williswillie
that sounds like bad actuators etc. Connect power directly to the appropriate pins on the connectors to the motor of your power window and see if it works then. If so it is possible that you have a ground failure etc. If it does not work it is your motor that is failing. Of course you can also try what the SM suggest
Afbeelding
“buzzing sound when not working. “ is usually caused by a bad lock assembly. Replacing it should fix your intermittent problems
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I disconnected the positive battery cable for about 5 min and then reconnected it, and the locks worked good for a couple unlocks and locks then quite. Power window rolled up as well.
door
Voeg je antwoord toe
Willie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 1,810
