Ga door naar hoofdinhoud
De Nissan Altima is een middelgrote auto geproduceerd door Nissan en is waarschijnlijk een voortzetting van de Nissan Bluebird-lijn, die in 1957 begon.
Cranking but won't start
My car started running hot. Heater wouldn'twork either. My boyfriend replaced the water pump and the 2 themostats. He drove it down the road it didn't get hot. He shut it off and went to start it back. Wouldn't start only crank. So he replaced the crank senor wasn't it. Checked the plugs. It's getting fire. The fuel pump is coming on. He also took the air mass senor out still wouldn't start. I took it to mechanic he's had it for a week. He still don't know either. But keeps telling me he'll have it fixed the next day.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
the fuel pump coming on does not put fuel in the engine. The injectors are responsible for that. You need fuel, air and spark. Assuming the air filter isn’t totally blocked which would cause it to flood, and the spark is good, then the injectors are not working. Could be a timing sensor, blocked injectors or computer.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Check your security system
door
have your mechanic check your heater core..
Plugged heater core.
Update (03/07/2019)
or a faulty thermost that is sticking.. or installed backwards..
has your mechanic pressure tested your cooling system? and performed a leak down test?
Have u tried the main
Voeg je antwoord toe
Heather zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,926
