Wet laptop while charging
I was in a rush this morning and spill my water bottle next to my laptop, when i came back home after 5h, i press the power button and it wont turn on. I found out there are water and quickly pull out the plug.
I heard that device with batery can short circuit, can still be dry out if you are lucky. But my laptop was plug all morning and the power button have been press 1-2 times by my dumbass.
Is there still hope if i disassemble and dry it out?
Is dit een goede vraag?
1 Opmerking:
Check and try to save your HDD first. Make sure its dry and use it on other PC/Laptop. Everything else can be replaced. You need professional help for rest of the thing as the damage has to be checked.
door Deel
Voeg een opmerking toe
