Ga door naar hoofdinhoud
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Vragen Bekijk alle
EMC 2742 late2013 , iMac 21.5 LCD ON, LED-backlight dark flickering
Hi,
I have a 21.5'' Late 2013 iMac Model A1418 (EMC 2742) , that was sold in JAPAN.
Display’s backlight doesn’t work now, When you look carefully, the thin liquid crystal display is shown.
Now, I’m testing: Thunderbolt2(edited from 3) to HDMI external display
So, How to check for broken parts?
What is the probable cause of this type of failure?
Where on the logic board is the fuse element for the backlight?
My son's MBP has the same symptoms and repaired the logic board, by Apple U$D450.
Are there any method for below,
What should be input to the terminal of the display power connector to light the backlight? for always LED backlight-ON use I will... If I can do.
Thanks
Update (03/01/2019)
Thank you Dan,
This is the screenshot of connected external display (TB2 to HDMI adapter to ext. Dell Display)
This is screenshot re-conect ORG back-light darkdown display de-touch Ext.display DELL. It looks LCD Montor sensor is Allive.
diagnostic
Shutdown Reason,Fan Diagnostics,Sensor Diagnostics,Battery Health
Normal,The fan appears to be working properly.,Temperature sensors appear to be working properly.,This Mac does not have an internal battery.
I tried to video-record "stage lighting effect" , there was no again bright of display.
However, another case incident was happen "flickering falsh and very dark" , Please see Uploaded Video.
When flickering, the brightness is differnt than Backlight-”off”, It was ON very small darkness.
This is more and More dark than normaly minimunum dispray brightness adjust (I feel about 1% as normaly brightness).
In the video, I am pushing the button, but I feel it is timing unrelated to flicker.
The video was recorded brighter than I saw with my eyes.
Flickering does not last forever.
Flickering did not happen after this recording, display kept very dark.
When "stage lighting effect" at once time ago , display LED worked normaly brightness about 50%.
The currentry flickering & brightness of LED-bucklight.
Where does this symptom occur when something is wrong?
Is dit een goede vraag?
3 opmerkingen
外部ディスプレイは機能しますか?
ある時点でディスプレイアセンブリを取り外しましたか?
Does the external display work?
Did you take the display assembly off at some point?
door
Thanks,
Now, External display is working well but slow response.
ThnderBolt-HDMI to external display SONY
After LED back-light lost, I took off Orginal display as Two connectors from logic-board for find SONY display.
few times restart iMac , then clean installed old OSX, then
Now working on Mojave.
Few times switch display .ORG 21.5 & SONY and both display , or AppleTV.
door
アプリをインストールするTG Proメインウィンドウのスナップショットを撮ってここに貼り付けると、Voeg afbeeldingen toe aan een bestaande vraag が表示されます。
Install the app TG Pro take a snapshot of the main window and paste it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
診断を受けるにはフルバージョンを入手する必要があります。あるいは、システムを再起動してキーボードのDキーを押して診断に入ることで、Appleオンボード診断を実行することもできます。 残念ながら、Appleの診断はTG Proほど有益ではありません。
ディスプレイを取り外したときにディスプレイのサーマルセンサーが損傷したか、ロジックボードへのケーブル接続が損傷したかのどちらかと思います。 どのセンサーが応答していないかを特定できるまで、どこを見ればいいのかわかりません。
参照Macスタートアップキーの組み合わせ
You’ll need to get the full version to get the diagnostics or you can also try running the Apple onboard diagnostics by restarting your system and pressing the D key on your keyboard to enter into diagnostics. Sadly, the Apple diagnostics is not as informative as the TG Pro.
I’m suspecting your either damaged the displays thermal sensor when you took the display off or you damaged the cable connection to the logic board. Until we can localize what sensor is not responding I can’t tell you where to look
Reference Mac startup key combinations
Was dit antwoord nuttig?
Score 2
17 opmerkingen:
Does diaagnostic of TG Pro Full Ver. find damege points?
I tried ORG display check.
It looks OK of the displays thermal sensor.
door
TG Proのフルバージョンから何がわかりましたか?
What did the full version of TG Pro tell you?
door
i found almost properly. Do I have to check more diaagnosticmethod on TG pro?
Date,Time,CPU Core 1 (C),CPU Core 2 (C),CPU Core 3 (C),CPU Core 4 (C),CPU PECI (C),CPU Proximity (C),GPU Diode (C),GPU Diode (Analog) (C),GPU PECI (C),GPU Proximity (C),LCD Monitor Proximity (C),LCD Monitor Proximity (C),PECI System Agent (C),Platform Controller Hub Die (C),Memory Module Proximity (C),DC In Proximity (C),Power Supply Secondary Heatsink (C),CPU Average (C),Computer Average (C),Main (RPM),Fan Average (RPM),Shutdown Reason,Fan Diagnostics,Sensor Diagnostics,Battery Health
2019-03-03,22:27:53,34,34,34,31,34,29,31,N/A,34,27,23,24,28,33,26,26,26,33,30,1400,1400,Normal,The fan appears to be working properly.,Temperature sensors appear to be working properly.,This Mac does not have an internal battery.
door
TG Proの診断機能から何がわかりましたか?
Again, what did the diagnostics within TG Pro tell you?
door
Diago. tell
Last Shutdown : Normal
Fans : The fan appers to be working properly.
Tempratures Sesors : Temprature sensors appear to be working properly.
Battery Health : This Mac does not have an internsl battry.
All green. Battery is grey
door
12 commentaren meer tonen
Voeg je antwoord toe
Mit SUZU zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 565
