Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Need to replace battery. 2.3 or 2.7 GHz?
I need to replace my MacBook Pro battery.
The battery is so swollen that the trackpad won't click. So I can't pull up the Apple menu and the “about my Mac" screen. I've replaced it before, so I searched ifixit for the part #: F163-019-1. I got no results. How can I buy the correct part?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
First let’s see exactly what machine you are running. Go to this site and input your serial number from the back of your machine: https://everymac.com/ultimate-mac-lookup...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you, Mayer. Useful.
door
This is the part you are looking for I believe MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery Afbeelding
Product
$69.99
Score 1
2 opmerkingen:
Thank you, Dan! I found it also on my own by selecting each possible speed and finding each led to the same part.
door
awesome! good luck with the replacement!
door
Voeg je antwoord toe
rileybk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 69
