Ga door naar hoofdinhoud
The JBL Charge 4 is a waterproof, Bluetooth capable speaker that additionally functions as a portable charger for smartphones. It is identifiable by its model number: CHARGE4S.
JBL Charge 4 speaker suddenly stops playing sound
My JBL Charge 4 bluetooth speaker was working fine until it suddenly stopped playing sound (even the ones it plays when it turns on, off, etc.). I don’t know what could’ve caused this since I don’t use the speaker on max volume. Speaker was charged and it connects fine, hasn’t gotten extremely wet either.
Is dit een goede vraag?
Score 7
11 opmerkingen
Jbl started having severe noise distortion and all of a sudden just stopped playing or making sounds at all. No power up or power down sound even though it seems to be connected to my phone. It is fully charged and brand new. Any advice?
door
Same problem with mine, though no noise distortion before it fell silent suddenly. It was playing normally, then suddenly nothing. No power up or power down sounds, no connect sounds though it is connecting. Nothing. Pretty much still new. What’s the problem here?
door
For the charge 4, the reset buttons changed to the play/pause button and the bluetooth button
door
anyone got a solution for this? my Charge 4 just stopped producing any sound for no absolute reason, even the on/off sound is not played now, it connects normally but totally silent. factory reset didn't solve it. any help?
door
Same for me - brand new and stopped producing sound out of nowhere - what a crap
door
6 commentaren meer tonen
Voeg een opmerking toe
9 Antwoorden
Het nuttigste antwoord
Try powering on yourJBL Charge 4 first and wait for the LED indicator to turn on. Then try holding down the play/pause button and the volume up button up to 20 seconds and that should factory reset your device. Then try again and see if it makes sound.
I personally have a JBL Xtreme and I’ve had similar problem and factory reset fixed mine. Hopefully it works for you too.
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
Tired that it didn't work for my charge 4
door
Same problem, tried factory reset but still no sound. I need help
door
Same for me, no sound....
door
GREAT now my JBL won’t even turn on after doing those steps!
door
Ok so this is the wrong combination for the Charge 4, mine also didn't reset and stopped turning on. I've finally found that to fix it again, you have to plug it in so the power lights up. Then hold Bluetooth and play buttons until it switches off. Then you can unplug and switch on as normal. That was an hour of stress I didn't need
door
2 commentaren meer tonen
Mine started working somehow, i pressed both the power and connect+ button together. While keeping these pressed, press the play and volume up. I somehow got mine back to life.
Try this again and again after putting into charge and removing it from charging.
1 Opmerking:
Download the JBL Connect app. Pair the speaker with your phone. Select upgrade speaker.
door
Download JBL Connect app. Pair Bluetooth speaker. Select Upgrade speaker.
1 Opmerking:
Worked like a charm although I don't understand how and why I was able to to upgrade my speaker off of my phone.....
door
mine did the same thing after falling. I took it apart and found the part the red arrow is pointing at was dislodged. I pushed it back in and it started working again but only when I’m pushing down on it. Not sure how to keep the downward pressure with glue.
I had this problem and in my case solution was surprisingly stupid. Apparently I was connected to speaker on 2 devices. On pc, which was the music source, and on phone, which I used to browse reddit. Eventually I was stumbling on videos on reddit, and even without sound when you start looking at them, speaker stops playing sound on pc. So basically try checking for when exactly music stops and if it’s somehow related to what you are doing at the moment.
My JBL charge 4 was playing music then all of a sudden it stopped playing it won't turn on but when I plug it in the power button light turns on but don't do nothing I tried pressing the power button plus volume up button and nothing
1 Opmerking:
Did you ever get the audio working on your charge4? Mine has no audio also.
door
Yes is not up to a month
2 opmerkingen:
Yes and is not up to a month what do you think
door
I did the reset thing
door
JBL charge 4, ic sound problem
1 Opmerking:
Same problem.
door
If hard reset doesn’t work, disassemble it( check youtube) the take a look if one of the wires is disconnected. This was my case, works fine now. I imagine the assembly process is flawed if this problem is common. I never dropped my speaker or nothing too.
Voeg je antwoord toe
SpeakerDude zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 188
Altijd: 48,380
