Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Home button do not respond
Home button do not respond time by time.
And ear speaker so quiet. No any damages or
water spills. Thanks for help!
Is dit een goede vraag?
Score -1
1 Opmerking
any ideas guys?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The home button not responding is probably the result of dust or a poor connection in the logic board. Here's a teardown to open it up and check out the connections. You can also blow some compressed air inside to clear out any dust.
As for the ear speaker, it's possible that there is a bad connection between the speaker and the logic board. More likely, however, is that the speaker is dying and needs to be replaced. Both can be done with the same teardown guide.
Was dit antwoord nuttig?
Voeg je antwoord toe
Vitali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 767
